Hello,
Is there a possibility to match LTE layer and UBBP boards on Huawei?
Matching Huawei LTE layer and UBBP boards depends on model series and revision compatibility.
How to improve UL throughput in Huawei LTE | 2 | 939 | September 27, 2021 | |
SFPs for CPRI in Huawei BTS3900 | 0 | 863 | June 18, 2021 | |
In Huawei how to check baseband boards pooling and cells association with pools/boards | 6 | 2180 | September 12, 2017 | |
Inter-vendor compatibility for 5G SCG and 4G MCG [Nokia and Huawei] | 0 | 33 | August 12, 2024 | |
Insert different control board on Huawei MA5800 X7 | 1 | 553 | March 19, 2020 | |
Load Balancing parameter setting for PRB and UE | 2 | 1901 | December 27, 2022 | |
LTE UE Category Counters | 0 | 609 | March 29, 2021 | |
LTE Multi Layer Balancing in Huawei | 1 | 919 | April 8, 2021 | |
Considerations for Upgrading IPs to Support 5G Traffic on Huawei LTE | 0 | 6 | October 19, 2024 | |
5G UE Nemo Compatible | 1 | 616 | March 15, 2021 |
