To measure UL QoE, throughput is not the best option since it will depend on the user need of big data bursts.
So what do you guys use to measure UL QoE?
You could consider UL Tx power not to be limited to 23 dBm in LTE and 24.5 dBm in NR NSA for the UE.
If this is OK then look at RB occupancy in UL.
If not over 95% then all is OK on cell.
Steps to check improvement of UL in case of Good radio condition | 0 | 531 | November 28, 2020 | |
How to calculate PUSCH Throughput? | 0 | 165 | April 22, 2024 | |
Estimate UL SINR using DL measurements in LTE and NSA NR | 1 | 926 | May 10, 2021 | |
Field test recommendations | 1 | 509 | April 2, 2021 | |
CA cells with bad DL/UL cell throughput | 3 | 776 | February 14, 2020 | |
Ul throughput enhacement in TDD | 2 | 457 | June 6, 2021 | |
Government worldwide 5G QoS requirement | 2 | 130 | June 14, 2024 | |
PPP layer data throughput | 0 | 368 | November 10, 2022 | |
How can we measure the noise on Uplink in 5G? | 5 | 1542 | February 23, 2022 | |
What's the best way to measure DC capable UEs throughput from statistics for Ericsson | 0 | 728 | January 10, 2018 |
