Hi Guys.
How to recover a packet that is discarded in PDCP layer in Download?
Hi, Is RLC SDU received at RLC layer?
If yes, then RLC will transmit RLC PDU…if no, then I believe that is called packet loss and you can not recover it as per my knowledge, thank you.
PDU and SDU | 7 | 2434 | January 23, 2024 | |
ARQ at RLC | 4 | 1205 | December 1, 2021 | |
How a pdsch packet decode takes place at each layer, from phy to app? | 1 | 342 | November 28, 2022 | |
UE RLC packet flow from SN1 to SN6 | 9 | 683 | October 9, 2021 | |
In DL PDCP -> RLC -> MAC flow, does each layer removes the header of previous layer? | 2 | 280 | December 14, 2023 | |
DL F1-U Packet Loss Rate | 0 | 1393 | January 4, 2022 | |
Points to check for Low DL/UL Throughput on PDCP layer from UE side in 5G SA case | 15 | 219 | March 12, 2024 | |
Number of NR-U DUD without any PDCP PDU sent over X2-U at gNB-CU | 1 | 93 | June 13, 2024 | |
Combined (NR and LTE) PDCP layer throughput | 3 | 1561 | June 12, 2021 | |
PDCP_SDU_VOL_DL_MB KPI explanation | 8 | 679 | June 12, 2023 |
