how to reduce RRC congestion in ZTE network. Even though the traffic volume is less but RRC congestion is more than 10 % in ZTE NW. what are the parameters to be check in RNC to reduce the RRC congestion pl
First of all check the reason of the congestion (power dl ,ul or code or CE dl ,ul or IUB or hspa users ) then we will go for the next step.
Related Topics
3G UPLINK Congestion | 5 | 1474 | March 25, 2021 | |
Control congestion For HSDPA cells | 1 | 672 | March 28, 2021 | |
Power Congestion | 5 | 2221 | June 9, 2020 | |
How to overcome traffic congestion? | 7 | 2010 | February 19, 2018 | |
Reduce CCE Failure Rate in low users/low utilized cells (LTE) | 5 | 1884 | March 8, 2021 | |
Reduce PRB/Increase Throughput of a congested Cell | 6 | 1561 | March 11, 2021 | |
Solution for 3G RRC call setup failure (cause admission control) | 6 | 2177 | April 29, 2021 | |
High Channel Utilization in 3G | 4 | 2964 | December 4, 2021 | |
How can I handle UL congestion for an overloaded cell? | 13 | 2420 | November 19, 2017 | |
Configure 3G to 2G fallback for calls when 3G network is congested | 4 | 1053 | April 18, 2022 |
