How to remove X2 interface for sites?
Hi Folks.
Vendor is Huawei.
I mean the X2 interface create automatically by the x2sonselfmanagement, when doing rmv x2interfacr it does not accept to remove or modify the automatically create x2.
First of all, disable the switch into GLOBALPROCSWITCH / X2SonSetupSwitch.
Than try to remove again.
Thanks mate, but I tried and it’s not working.
I even tried deactivated 4G-5G X2 selfcreation but can’t yet remove X2 autocreated.
