How to Resolve Password Errors on Ericsson 3G Sites [Password File Fault]
Hello Everyone.
I am trying to Fix this alarm on 3G Site on Ericsson Technology using this command below:
passwd
However, I keep encountering the following errors:
Error 1:
The current password is incorrect!
Syntax: passwd ; <current password> ; <new password>
Error 2:
$ Enter new password:
Unable to set the password. The value provided for the new password does not meet the length or complexity requirements. See manual page for detailed instructions.
Enter new password:
Too many attempts, aborting
Could someone please assist with this issue? Thanks in advance!
Hi, @Youssef_1, make sure you are using correct password.
For the second error: password require upper/lower case, numbers and at least one special character.
If all above doesn’t helps, then recomission DUW with formatting c2 and d drives.
Thank you for the your quick reqponse,
When trying to excute the passwd command this what I see :
how to get the old password ??
The alarm is the following :
my bad
you can’t, recomission is only option
Hhhhhh, it’s Okay,
My question is what is Recomisison ?
What is the purpose of recomission a Site ?
in case of recomission DUW does it have any affect on traffic or service, or making a Site Restarted.
Thanks @vlr9999 for your helpfull guideline, appreciate.!!
Recomission is the integration from scratch: formatting drives, copy upgrade package, load configuration and so on. It is 15-30 min on-site activity for experienced person and 1hr for not so.
I’m sure there is no way to reset password if you forget it.
Okay @vlr9999 Thank you so much for Your help !!
I really Appreciate your feedback !!
the passwd file was missing on disk c inside the security folder, back up the file from another site and place it in the specified folder… the next time you reconfigure a 3G it will not give this alarm
Placing a file inside the DUW disk?
I think that’s not a simple copy-paste operation.
Please can you share the command to do this?
It’s via FTP, I’m going to record a video and play it on my YouTube channel and post the link here
CHECK IN THE DUW SECURITY DIRECTORY IF WE HAVE THE PASSWD FILE:
cd /c/security
ls
ACCESS A NEIGHBORHOOD SITE OR SAME REGIONAL SITE AND OBTAIN THE PASSWD FILE FROM IT:
cd /c/security
ls
ftget  passwd
ls
INSTALLING PASSWORD FILE EXTRACTED FROM NEIGHBORHOOD SITE:
cd /c/security
ls
ftput  passwd
ls
SAVE A CV AND APPLY RESTART
Cvms Passwd_ok
Cvset Passwd_ok
reload
