β¦ when i have a DUW3101 ,c2,d of SW17 and Upgrage Packed SW22
Hi, @vietphamvn. You canβt. You can jump over 1 release, as I remember. For example: upgrade to sw22 only possible from sw20. Consult ericsson support for more accurate answer. Anyway, for local upgrade steps are:
0. On your laptop: start ftp server, place UP under default ftp folder
- On RBS: create UP
- Fill in all fields
- Then press install package, after - select full install
- Next Verify Package, if actionResult is Upgrade Possible β Upgrade Node (select Hard Upgrade)
- After RBS restarted β Confirm Upgrade
Thanks a lot !
