Upgrade the Cluster Control Plan
[root@masternode ~]# rpm -qa | grep -E 'kubeadm|kubelet|kubectl
kubelet-1.23.2-0.x86_64
kubeadm-1.23.2-0.x86_64
kubectl-1.23.2-0.x86_64
[root@masternode ~]# clear
[root@masternode ~]# kubectl get nodes
NAME STATUS ROLES AGE VERSION
masternode.example.com Ready control-plane,master 29m v1.23.2
workernode1.example.com Ready <none> 27m v1.23.2
workernode2.example.com Ready <none> 27m v1.23.2
[root@masternode ~]# rpm -qa | grep -E 'kubeadm|kubelet|kubectl'
[root@masternode ~]# kubeadm upgrade plan
[upgrade/config] Making sure the configuration is correct:
[upgrade/config] Reading configuration from the cluster...
[upgrade/config] FYI: You can look at this config file with 'kubectl -n kube-system get cm kubeadm-config -o yaml'
[preflight] Running pre-flight checks.
[upgrade] Running cluster health checks
[upgrade] Fetching available versions to upgrade to
[upgrade/versions] Cluster version: v1.23.17
[upgrade/versions] kubeadm version: v1.23.2
I0325 21:36:56.074773 33874 version.go:255] remote version is much newer: v1.26.3; falling back to: stable-1.23
[upgrade/versions] Target version: v1.23.17
[upgrade/versions] Latest version in the v1.23 series: v1.23.17
[root@masternode ~]# yum install -y kubeadm-1.23.17-0 --disableexcludes=kubernetes
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.aktkn.sg
* extras: mirror.aktkn.sg
* updates: mirror.aktkn.sg
kubernetes/x86_64/signature | 454 B 00:00:00
kubernetes/x86_64/signature | 1.4 kB 00:00:00 !!!
kubernetes/x86_64/primary | 126 kB 00:00:01
kubernetes 941/941
Resolving Dependencies
--> Running transaction check
---> Package kubeadm.x86_64 0:1.23.2-0 will be updated
---> Package kubeadm.x86_64 0:1.23.17-0 will be an update
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Updating:
kubeadm x86_64 1.23.17-0 kubernetes 9.4 M
Transaction Summary
Upgrade 1 Package
Total download size: 9.4 M
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
52c389a4598f61bdf251c5ebcdf2475c32254e3ea85027e204ccc0356e7a1be1-kubeadm-1.23.17-0.x86_64.rpm | 9.4 MB 00:00:03
Running transaction test
Transaction test succeeded
Running transaction
Updating : kubeadm-1.23.17-0.x86_64 1/2
Cleanup : kubeadm-1.23.2-0.x86_64 2/2
Verifying : kubeadm-1.23.17-0.x86_64 1/2
Verifying : kubeadm-1.23.2-0.x86_64 2/2
Updated:
Complete!'
masternode.example.com Ready control-plane,master 31m v1.23.2
workernode1.example.com Ready <none> 29m v1.23.2
workernode2.example.com Ready <none> 29m v1.23.2
[root@masternode ~]# kubectl drain masternode.example.com
node/masternode.example.com cordoned
error: unable to drain node "masternode.example.com" due to error:cannot delete DaemonSet-managed Pods (use --ignore-daemonsets to ignore): kube-system/calico-node-d6gn5, kube-system/kube-proxy-gdd74, continuing command...
There are pending nodes to be drained:
[root@masternode ~]# kubectl drain masternode.example.com --ignore-daemonsets
node/masternode.example.com already cordoned
WARNING: ignoring DaemonSet-managed Pods: kube-system/calico-node-d6gn5, kube-system/kube-proxy-gdd74
evicting pod kube-system/coredns-64897985d-sgx7w
evicting pod kube-system/coredns-64897985d-h5kw7
pod/coredns-64897985d-sgx7w evicted
pod/coredns-64897985d-h5kw7 evicted
node/masternode.example.com drained
masternode.example.com Ready,SchedulingDisabled control-plane,master 32m v1.23.2
workernode1.example.com Ready <none> 30m v1.23.2
workernode2.example.com Ready <none> 30m v1.23.2
[root@masternode ~]# kubectl get pods -A
NAMESPACE NAME READY STATUS RESTARTS AGE
kube-system calico-kube-controllers-85b5b5888d-jd7mr 1/1 Running 0 30m
kube-system calico-node-487bp 1/1 Running 0 30m
kube-system calico-node-7rhh8 1/1 Running 0 30m
kube-system calico-node-d6gn5 1/1 Running 0 30m
kube-system coredns-64897985d-s8l8g 1/1 Running 0 24s
kube-system coredns-64897985d-zxkcr 1/1 Running 0 24s
kube-system etcd-masternode.example.com 1/1 Running 6 32m
kube-system kube-apiserver-masternode.example.com 1/1 Running 0 32m
kube-system kube-controller-manager-masternode.example.com 1/1 Running 0 32m
kube-system kube-proxy-gdd74 1/1 Running 0 32m
kube-system kube-proxy-w2sql 1/1 Running 0 30m
kube-system kube-proxy-w944r 1/1 Running 0 30m
kube-system kube-scheduler-masternode.example.com 1/1 Running 0 32m
[root@masternode ~]# kubectl get pods -A -o wide
NAMESPACE NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
kube-system calico-kube-controllers-85b5b5888d-jd7mr 1/1 Running 0 30m 172.16.133.129 workernode1.example.com <none> <none>
kube-system calico-node-487bp 1/1 Running 0 30m 192.168.29.201 workernode1.example.com <none> <none>
kube-system calico-node-7rhh8 1/1 Running 0 30m 192.168.29.202 workernode2.example.com <none> <none>
kube-system calico-node-d6gn5 1/1 Running 0 30m 192.168.29.200 masternode.example.com <none> <none>
kube-system coredns-64897985d-s8l8g 1/1 Running 0 27s 172.16.14.67 workernode2.example.com <none> <none>
kube-system coredns-64897985d-zxkcr 1/1 Running 0 27s 172.16.133.130 workernode1.example.com <none> <none>
kube-system etcd-masternode.example.com 1/1 Running 6 32m 192.168.29.200 masternode.example.com <none> <none>
kube-system kube-apiserver-masternode.example.com 1/1 Running 0 32m 192.168.29.200 masternode.example.com <none> <none>
kube-system kube-controller-manager-masternode.example.com 1/1 Running 0 32m 192.168.29.200 masternode.example.com <none> <none>
kube-system kube-proxy-gdd74 1/1 Running 0 32m 192.168.29.200 masternode.example.com <none> <none>
kube-system kube-proxy-w2sql 1/1 Running 0 30m 192.168.29.202 workernode2.example.com <none> <none>
kube-system kube-proxy-w944r 1/1 Running 0 30m 192.168.29.201 workernode1.example.com <none> <none>
kube-system kube-scheduler-masternode.example.com 1/1 Running 0 32m 192.168.29.200 masternode.example.com <none> <none>
workernode1.example.com Ready <none> 31m v1.23.2
workernode2.example.com Ready <none> 31m v1.23.2
[root@masternode ~]# kubeadm version -o short
v1.23.17
[root@masternode ~]# yum install -y kubelet-1.23.17-0 kubectl-1.23.17-0 --disableexcludes=kubernetes
---> Package kubectl.x86_64 0:1.23.2-0 will be updated
---> Package kubectl.x86_64 0:1.23.17-0 will be an update
---> Package kubelet.x86_64 0:1.23.2-0 will be updated
---> Package kubelet.x86_64 0:1.23.17-0 will be an update
--> Processing Dependency: kubernetes-cni >= 1.1.1 for package: kubelet-1.23.17-0.x86_64
---> Package kubernetes-cni.x86_64 0:0.8.7-0 will be updated
---> Package kubernetes-cni.x86_64 0:1.2.0-0 will be an update
Updating:
kubectl x86_64 1.23.17-0 kubernetes 9.8 M
kubelet x86_64 1.23.17-0 kubernetes 21 M
Updating for dependencies:
kubernetes-cni x86_64 1.2.0-0 kubernetes 17 M
Transaction Summary
Upgrade 2 Packages (+1 Dependent package)
Total download size: 48 M
(1/3): cb2ed23fb25cc5b2f73ffc665c3b71e87bce012ec4cf7750e2246f1b48afd34e-kubectl-1.23.17-0.x86_64.rpm | 9.8 MB 00:00:03
(2/3): 0f2a2afd740d476ad77c508847bad1f559afc2425816c1f2ce4432a62dfe0b9d-kubernetes-cni-1.2.0-0.x86_64.rpm | 17 MB 00:00:01
(3/3): 552c4d4494c1de798baf4b52c0a27a3e9a63740900a76f30997210edbfcb7d99-kubelet-1.23.17-0.x86_64.rpm | 21 MB 00:00:05
Total 8.0 MB/s | 48 MB 00:00:05
Running transaction
Updating : kubelet-1.23.17-0.x86_64 1/6
Updating : kubernetes-cni-1.2.0-0.x86_64 2/6
Updating : kubectl-1.23.17-0.x86_64 3/6
Cleanup : kubelet-1.23.2-0.x86_64 4/6
Cleanup : kubernetes-cni-0.8.7-0.x86_64 5/6
Cleanup : kubectl-1.23.2-0.x86_64 6/6
Verifying : kubernetes-cni-1.2.0-0.x86_64 1/6
Verifying : kubelet-1.23.17-0.x86_64 2/6
Verifying : kubectl-1.23.17-0.x86_64 3/6
Verifying : kubernetes-cni-0.8.7-0.x86_64 4/6
Verifying : kubectl-1.23.2-0.x86_64 5/6
Verifying : kubelet-1.23.2-0.x86_64 6/6
Updated:
kubectl.x86_64 0:1.23.17-0 kubelet.x86_64 0:1.23.17-0
Dependency Updated:
Complete!
[root@masternode ~]# systemctl daemon-reload
[root@masternode ~]# systemctl restart kubelet
[upload-config] Storing the configuration used in ConfigMap "kubeadm-config" in the "kube-system" Namespace
[upgrade/versions] kubeadm version: v1.23.17
I0325 21:41:05.479475 37110 version.go:256] remote version is much newer: v1.26.3; falling back to: stable-1.23
[root@masternode ~]# kubeadm upgrade apply v1.23.17
[upgrade/version] You have chosen to change the cluster version to "v1.23.17"
[upgrade/confirm] Are you sure you want to proceed with the upgrade? [y/N]: y
[upgrade/prepull] Pulling images required for setting up a Kubernetes cluster
[upgrade/prepull] This might take a minute or two, depending on the speed of your internet connection
[upgrade/prepull] You can also perform this action in beforehand using 'kubeadm config images pull'
[upgrade/apply] Upgrading your Static Pod-hosted control plane to version "v1.23.17"...
Static pod: kube-apiserver-masternode.example.com hash: dd5a08506ef916bb8ecb7f0f4871bbad
Static pod: kube-controller-manager-masternode.example.com hash: 435d804c86bdb43c4e30468b1d4f88fa
Static pod: kube-scheduler-masternode.example.com hash: 16a82ff09e029b370c5232648600654f
[upgrade/etcd] Upgrading to TLS for etcd
Static pod: etcd-masternode.example.com hash: 3102c76fbb647e32ba918aa4a8f5c7f9
[upgrade/staticpods] Preparing for "etcd" upgrade
[upgrade/staticpods] Renewing etcd-server certificate
[upgrade/staticpods] Renewing etcd-peer certificate
[upgrade/staticpods] Renewing etcd-healthcheck-client certificate
[upgrade/staticpods] Moved new manifest to "/etc/kubernetes/manifests/etcd.yaml" and backed up old manifest to "/etc/kubernetes/tmp/kubeadm-backup-manifests-2023-03-25-21-41-54/etcd.yaml"
[upgrade/staticpods] Waiting for the kubelet to restart the component
[upgrade/staticpods] This might take a minute or longer depending on the component/version gap (timeout 5m0s)
Static pod: etcd-masternode.example.com hash: 1a799184d432cabf75ce0db5052a46e0
[apiclient] Found 1 Pods for label selector component=etcd
[upgrade/staticpods] Component "etcd" upgraded successfully!
[upgrade/etcd] Waiting for etcd to become available
[upgrade/staticpods] Writing new Static Pod manifests to "/etc/kubernetes/tmp/kubeadm-upgraded-manifests1963023519"
[upgrade/staticpods] Preparing for "kube-apiserver" upgrade
[upgrade/staticpods] Renewing apiserver certificate
[upgrade/staticpods] Renewing apiserver-kubelet-client certificate
[upgrade/staticpods] Renewing front-proxy-client certificate
[upgrade/staticpods] Renewing apiserver-etcd-client certificate
[upgrade/staticpods] Moved new manifest to "/etc/kubernetes/manifests/kube-apiserver.yaml" and backed up old manifest to "/etc/kubernetes/tmp/kubeadm-backup-manifests-2023-03-25-21-41-54/kube-apiserver.yaml"
Static pod: kube-apiserver-masternode.example.com hash: a3e1ed5f65aebe0053ce74cce7c145ec
[apiclient] Found 1 Pods for label selector component=kube-apiserver
[upgrade/staticpods] Component "kube-apiserver" upgraded successfully!
[upgrade/staticpods] Preparing for "kube-controller-manager" upgrade
[upgrade/staticpods] Renewing controller-manager.conf certificate
[upgrade/staticpods] Moved new manifest to "/etc/kubernetes/manifests/kube-controller-manager.yaml" and backed up old manifest to "/etc/kubernetes/tmp/kubeadm-backup-manifests-2023-03-25-21-41-54/kube-controller-manager.yaml"
Static pod: kube-controller-manager-masternode.example.com hash: 698d8d65737478f3315f845c27ff400d
[apiclient] Found 1 Pods for label selector component=kube-controller-manager
[upgrade/staticpods] Component "kube-controller-manager" upgraded successfully!
[upgrade/staticpods] Preparing for "kube-scheduler" upgrade
[upgrade/staticpods] Renewing scheduler.conf certificate
[upgrade/staticpods] Moved new manifest to "/etc/kubernetes/manifests/kube-scheduler.yaml" and backed up old manifest to "/etc/kubernetes/tmp/kubeadm-backup-manifests-2023-03-25-21-41-54/kube-scheduler.yaml"
Static pod: kube-scheduler-masternode.example.com hash: eba19525bc7394f7ff9ce340ed12b614
[apiclient] Found 1 Pods for label selector component=kube-scheduler
[upgrade/staticpods] Component "kube-scheduler" upgraded successfully!
[upgrade/postupgrade] Applying label node-role.kubernetes.io/control-plane='' to Nodes with label node-role.kubernetes.io/master='' (deprecated)
[kubelet] Creating a ConfigMap "kubelet-config-1.23" in namespace kube-system with the configuration for the kubelets in the cluster
NOTE: The "kubelet-config-1.23" naming of the kubelet ConfigMap is deprecated. Once the UnversionedKubeletConfigMap feature gate graduates to Beta the default name will become just "kubelet-config". Kubeadm upgrade will handle this transition transparently.
[kubelet-start] Writing kubelet configuration to file "/var/lib/kubelet/config.yaml"
[bootstrap-token] configured RBAC rules to allow Node Bootstrap tokens to get nodes
[bootstrap-token] configured RBAC rules to allow Node Bootstrap tokens to post CSRs in order for nodes to get long term certificate credentials
[bootstrap-token] configured RBAC rules to allow the csrapprover controller automatically approve CSRs from a Node Bootstrap Token
[bootstrap-token] configured RBAC rules to allow certificate rotation for all node client certificates in the cluster
[addons] Applied essential addon: CoreDNS
[addons] Applied essential addon: kube-proxy
[upgrade/successful] SUCCESS! Your cluster was upgraded to "v1.23.17". Enjoy!
s
systemctl restart kubelet[root@masternode ~]# systemctl restart kubelet
[root@masternode ~]# kubectl uncordon masternode.example.com
node/masternode.example.com uncordoned
masternode.example.com Ready control-plane,master 38m v1.23.17
workernode1.example.com Ready <none> 37m v1.23.2
workernode2.example.com Ready <none> 37m v1.23.2
Worker Node Upgrade
[root@workernode1 ~]# yum install -y kubeadm-1.23.17-0 --disableexcludes=kubernete
Updating:
Transaction Summary
Upgrade 1 Package
52c389a4598f61bdf251c5ebcdf2475c32254e3ea85027e204cc 0% [ ] 0.0 B/s | 0 B --:--:-- ETA
52c389a4598f61bdf251c5ebcdf2475c32254e3ea85027e204ccc0356e7a1be1-kubeadm-1.23.17-0.x86_64.rpm | 9.4 MB 00:00:02
Running transaction
Updated:
Complete!
masternode.example.com Ready control-plane,master 42m v1.23.17
workernode1.example.com Ready <none> 40m v1.23.2
workernode2.example.com Ready <none> 40m v1.23.2
[root@masternode ~]# kubectl drain workernode1.example.com
workernode1.example.com Ready,SchedulingDisabled <none> 40m v1.23.17
[root@workernode1 ~]# kubeadm upgrade node
[upgrade] Reading configuration from the cluster...
[upgrade] FYI: You can look at this config file with 'kubectl -n kube-system get cm kubeadm-config -o yaml'
[preflight] Skipping prepull. Not a control plane node.
[upgrade] Skipping phase. Not a control plane node.
[upgrade] The configuration for this node was successfully updated!
[upgrade] Now you should go ahead and upgrade the kubelet package using your package manager.
[root@workernode1 ~]# yum install -y kubelet-1.23.17-0 kubectl-1.23.17-0 --disableexcludes=kubernetes
Updating:
Transaction Summary
(1/3): cb2ed23fb25cc5b2f73ffc665c3b71e87bce012ec4cf7750e2246f1b48afd34e-kubectl-1.23.17-0.x86_64.rpm | 9.8 MB 00:00:01
(2/3): 552c4d4494c1de798baf4b52c0a27a3e9a63740900a76f30997210edbfcb7d99-kubelet-1.23.17-0.x86_64.rpm | 21 MB 00:00:02
(3/3): 0f2a2afd740d476ad77c508847bad1f559afc2425816c1f2ce4432a62dfe0b9d-kubernetes-cni-1.2.0-0.x86_64.rpm | 17 MB 00:00:01
Total 14 MB/s | 48 MB 00:00:03
Running transaction
Updated:
Dependency Updated:
Complete!
[root@workernode1 ~]# systemctl daemon-reload
[root@workernode1 ~]# systemctl restart kubelet
[root@masternode ~]# kubectl uncordon workernode1.example.com
node/workernode1.example.com uncordoned
masternode.example.com Ready control-plane,master 44m v1.23.17
workernode1.example.com Ready <none> 42m v1.23.17
workernode2.example.com Ready <none> 42m v1.23.17 s
LinkedIn:
