How UE get to know about which technology is configured in network side TDD and FDD?
Also: how UE get to know about either it is Normal or Extended CP?
It check sib 1 message and for CP type check sib2 having UL cyclic length as len2.
Len 2 indicates Extended CP.
Len 1 indicates Normal CP.
From the signaling message can we know if site is LTE-only or EN-DC? | 2 | 703 | May 3, 2021 | |
How LTE UE knows the location of PSS and SSS? | 0 | 387 | December 11, 2022 | |
Does anyone know how to check behavior of DCI based BWP switching on QXDM? | 6 | 495 | October 23, 2022 | |
Parameter to check in QXDM log for HANDOVER | 4 | 2454 | March 16, 2020 | |
From which message can we check if UE support VoLTE or not? | 3 | 451 | March 30, 2022 | |
Check if user selected 4G as Preferable Network (instead of 5G)? | 2 | 411 | April 25, 2021 | |
How does UE come to know about suitable carrier in the initial search procedure | 0 | 714 | February 14, 2018 | |
In EN-DC, how SN PDCP decides how much data to forward toward SN RLC and MN RLC? | 5 | 699 | December 13, 2021 | |
Check encryption mode in 4G | 6 | 479 | March 17, 2021 | |
How UE indicate the presence of csi part 2? | 0 | 1429 | March 15, 2021 |
