How uplink MCS selection happens?
By bler, sinr or any others?
MCS selection based on SINR.
SINR Target adjusted based on BLER.
In Nokia Fast Uplink link adaption (F-ULA) implementation,uplink SINR calculated based on SRS and DMRS signal and calculated SINR was corrected by BLER value.
Related Topics
MCS adaptation in UL | 6 | 1101 | March 30, 2022 | |
How the UE determines MCS that is reported as part of CQI feedback? | 7 | 659 | September 11, 2023 | |
Closed loop power control on SA | 47 | 1852 | August 31, 2023 | |
How to know which MCS to choose? | 3 | 1609 | April 19, 2022 | |
How does UE select a particular PLMN selection in 5G? | 6 | 2107 | April 9, 2021 | |
Massive MIMO Layers (8 layers) vs RF condition (SINR) | 1 | 742 | October 7, 2020 | |
DL BLER shoots to 70% at run time in 5G SA while in starting DL BLER seen around 5% | 4 | 275 | June 16, 2024 | |
UL SINR in 5G NR SA | 12 | 3200 | August 5, 2021 | |
Adaptive PMI weight | 10 | 2058 | September 14, 2021 | |
SINR using scanner - Reference signal based or PSS/SSS based? | 2 | 484 | February 21, 2021 |
