How we can check eutranrelations of cell in ZTE?
Hi ZTE Experts.
Please confirm how we can check eutranrelations of cell?
First check relation defintion in externaleutran tab.
Then check eutranrelation.
Externaleutran is MO name, right?
Yes, correct.
For example, if you want to check Cell A is a neighbor of B so first you have to check in externaleutrancell MO that cell B definition is defined against site of Cell A.
Then if its available check in eutranrelation.
I want to check interfrequency parameters for which I need earfcn wise parameters value against each cell.
Which interfreq parameter do you need to check on relation level?
earfcn is available in externaleutrancell.
Do you mean multiple target earfcn against one cell in this MO?
Yes.
In external MO, neighbours are defined against site which means Source is site, and Target are cells.
But I need target as earfcn.
For ZTE OEM.
Target cells have external definition in which EARFCN is also available.
Like this earfcn are mentioned in external MO.
