Hello All.
How we can convert Cell id from hexadecimal to decimal?
cd90d801108
Hello All.
cd90d801108
What will be the effect if I set 3 apart from 03 in MNC?
4G, Nokia vendor.
No effect.
But as per 3GPP specs MNC should be of 2 digits.
Yes, but Nokia handle it.
I have Ericsson.
Oh, ok. Ericsson am not sure.
MCC is 3 digits, MNC is 2 digits in Ericsson.
What will happen if I set MNC only one digit?
It’s coded. Check if you change manually.
It’s regulation.
Looking at which Core node?
I think UE will not connect to network as 3GPP defined MNC should be only 2 or 3 digit.
Cell id= Mod (hexa,256)
Lnbts id= (Hexa-cell id)/256
