HUA 3G UE Trace
Hi all,
I would like to ask about the analysis/decoding of HUA 3G UE traces. THe files are in *.tmf format.
Is Agileto supporting it?
Thanks in advance for you feedback
Regards
Grish
Hello
         which tool ,are you using to run the UE traces?
BR,Shakeel
HI,
I am using M2000 (the HUA) OSS, to get the UE traces.
Regards
Grish
I suggest to use huawei FMA tools to process the traces.
Huawei FMA tool is not for sale by Huawei… Huawei is our vendor.
we used to used Actix Analyzer to open this type of files, but I have not seen a tmf file in a long time, you can give it a try if you have licenses around.
