Hi,
Could you tell the “BLER” commands (targets or types) for huawei. Thanks
MOD CELLALGOSWITCH: LocalCellId=0, CqiAdjAlgoSwitch=DlVarIBLERtargetSwitch-1
Hope it works
Related Topics
DL User Throughput (small packet) | 1 | 576 | June 15, 2024 | |
What parameter in Huawei LTE limits service by distance | 1 | 2496 | May 21, 2019 | |
MML command to check Filter Coefficient | 3 | 510 | October 15, 2020 | |
How to activate dynamic BLER in DL? | 2 | 363 | June 21, 2023 | |
Block the UE to latch on 4G from RAN node end | 3 | 455 | May 15, 2021 | |
Parameter to reduce MCS fluctuation | 0 | 454 | June 16, 2021 | |
Feature/switch to increase 2G capacity in Huawei | 0 | 288 | September 25, 2021 | |
LTE Multi Layer Balancing in Huawei | 1 | 911 | April 8, 2021 | |
Recommendations to DLSCHSTRATEGY and RBGALLOCSTRATEGY in LTE with High PRB Usage | 2 | 871 | June 28, 2022 | |
Parameter to Forbid PS UTRAN HO | 3 | 358 | March 5, 2021 |
