Hi,
is there possibility to get from Huawei U2020 S1 trace - a statistics of RN causes of all call Ids in the traces, in some quick way, or we need to go one by one call to check ? If it is possible to handle trace results regarding the statistics , causes, and suggested solutions, with some additional internal Huawei, what is the name of that internal tool ? Thankyou !
Hello all ,
Which Huawei internal tool, is doing advanced parsing and statistical analysis of , for example S1 traces ?
If you have any way to convert the trace to pcap then it’s easy to get that
Hi Jr_Mg,
thanks for answering !
I can do the export - only to .tmf format.
Not aware of .pcap options …
Which free tool actually can open that format of traces ?
BRs, P:)
Wireshark it’s free and can open .cap .pcap and .pcapng files . Now to open .tmf there’s an old perl script in github but havent use it before. I can try to translate it to python but just to test I will need a .tmf sample file if you can share it please(private message)
