i found directed signaling connection reestablishment msg but i cant understand it
What is the cause of CSFB failure here
I think event 2F didn’t finish
Bro what strategy for CSFB you are using ?
Check inter rat NBRs on LTE side defined correctly specially TA SC & if you are using blind HO on the same sector
From 3G side check RTWP if it’s high or not ?
