Is there any ideal value for RRC Connected Users LTE license such as the quality of service guaranteed?
The thing is, I have a site with E-RAB No Radio Resources failures due to the lack of RRC Connected Users license.
Why don’t you increase the license according to the max per hour?
Thanks @AhmedKenzy.
Yes, I see what you mean but I wanted to know if there is a value of which the quality of service is “guaranteed”.
For instance, in my scenario I have two LTE carriers with (20MHz+10MHz), RRC Connected Users license is 225.
Currently, DL PRB>80%, is it worth it to expand the license or another expansion solution should be considered (e.g. adding another carrier).
In your situation you should do both in order no to lose this potential revenue
Increase the RRC license to admit those extra users and check for suitable solution for the PRB usage
Load balancing, split sector, adding carriers or whatever according to your situation
Hi All,
How many max number of RRC connected user in one cell?
And where do we get this info?
His usually depends on the licence.
The physical limitation I am aware of is the UBBP (which may support up to 3000 depending on specific types).
Practically speaking, what I consider in network:
- 2T2R: 150 users
- 4T4R: 300 users
- If CA exist, add 150
This is per eNodeB
Rrc users license per cell always.
Where can I get this in logs?
If UE logs not sure about it. If cell is overloaded you will get E-RAB failure due to no radio resources.
But the actual site capabilities should be acquired through OSS.
600 RRC connected users / sector.
