If support for n26 is 0 can we say ue can do the dual registration?
Related Topics
UE support single or dual registration support in 5G SA | 9 | 251 | September 11, 2024 | |
UE doing Dual-Co but not sending/receiving any Data | 0 | 399 | March 3, 2021 | |
How will UE register SA Core and 4G EPC independently? | 2 | 342 | October 15, 2022 | |
Can same cell in 5G be used both as NSA and SA? | 2 | 480 | November 1, 2023 | |
If UE doesn't support a band than will Event A2 will trigger for inter frequency measurement? | 1 | 221 | August 27, 2023 | |
Does UE with CORE restriction measure 5G NR cell? | 2 | 370 | February 21, 2021 | |
If a UE doesn't support DSS in NSA mode won't it support in SA mode also? | 2 | 361 | April 21, 2021 | |
NR CA not working | 3 | 379 | March 28, 2022 | |
How to verify intra band non-contigurous CA UE capability with the supportedbandcombinationlist | 0 | 27 | September 4, 2024 | |
Is it possible UE to have 4 antennas but chipset 2 layers only? | 3 | 314 | October 23, 2022 |
