Hi Experts I have a question:
In a LTE MIMO 4x4 cell how does the 2x2 MIMO UEs are distribuited across the 4 antennas?
UE selects the 2 antennas to use or in RECONFIGURATION MESSAGE networks tells the UE what antennas to use?
Think in 2x2 scenario, 4x4 cell sends 1st stream through 2 antennas and 2nd stream through other 2 antennas.
MIMO 2x4 | 1 | 1558 | March 27, 2021 | |
How does the relationship between antennas and the eNodeB work in a MIMO (6x6) setup? | 0 | 58 | August 1, 2024 | |
How 2 similar UE having same quality are scheduled? | 2 | 434 | August 16, 2021 | |
Can we use 4x4 MIMO per user in mmWave? | 5 | 1113 | June 27, 2023 | |
Max RxTx Capabilities of 5G UE | 7 | 1033 | February 27, 2021 | |
Is simple 4X4 LTE TDD without beamforming MU-MIMO possible? | 2 | 1901 | June 12, 2018 | |
In NSA 2x2 is Uplink MIMO supported? | 1 | 527 | July 29, 2022 | |
Explaining MIMO, Number of layers and Transmission Modes | 2 | 1408 | October 18, 2022 | |
Does UE has separate antennas for LTE and 5G transmission? | 2 | 274 | August 31, 2023 | |
RAT Selection in Roaming: 3G vs. 2G/4G | 0 | 48 | July 30, 2024 |
