Hi all.
In connected state, shall UE read MIB continuously?
Is it an expected behaviour?
Or it depends on UE chipset design also?
Hi all.
Every 40ms will trigger.
It will be as per the spec.
Agreed.
I mean to ask where are a connected state UE data transfer is going on, or pws is going on, shall read MIB after a certain interval?
UE is in data transfer state, or UE shall read it once like they simulator used to work?
Can you please explain if possible which part you are referring?
