In huawei, if I configure 15 hsdpa codes with manual allocation setting, there will not be hs traffic, what is the logic ?
You mean static configuration not dynamic ?
Yes. R99 traffic can be shown but hs zero
You may suffer from code cong
Code congestion has nothing to do with hsdpa service establishment because its codes already allocated statically
Are there alarms?
No, but when you type DSP UCELL you get hsdpa setup failure in output
Have you configured other code numbers i.e. 5,7,10,13,15
What about license ?
Yes when less number of codes configured hs traffic shows up, but am asking about why it was zero when codes set to 15 statically
As i remember when the code allocated manually its the minimum code allocated for the ue when it intiate the service so it will give one user the 15 codes (ideal cases) but when other user try to initiate service there will be no codes available.
If there any users with other services there will be no codes available for the hs service
What are bomber of hs scch codes ?
It is 4 codes
May be this is the reason. Kindly try 2 hsscch
This the min yes ?
For static no min or max just one static value
Ohh yes …
Try set 2 hsscch code.
Remember that if you set to 15 hsdpa codes there will be no voice on this carrier, sure?
I think when u set 15 Hsdpa codes manuly/permanently No HSSCH (sf = 128) can be used so no hsdpa related signlling/scheduling will be availale and consequently no hsdpa traffic.
It is like having no available pdcch resources in lte which will end up with having no traffic resources allocated in PDSCH.
