In NSA, does UE have a signalling plane with gNB, or is it only with eNB?
In option 7 series and option 6 UE exchange signaling with gNodeB.
And option 3 series and option 5 the signaling anchor is eNodeB.
It depends on the deployment option that your MNO decided to start with…
In option 3 and 5, is there a way I can push gNB cell info?
SRB3 includes signalling MR to gNB in option 3 if you enable.
Is SRB3 a parameter on Core or eNB?
MR?
Signalling Radio Bearers, as you asked signalling in NSA scenarios.
It can be enabled with a parameter if UE support.
Measurement Reports.
Check SRB in 5G.
In Nokia, srb3supportenabled under NRBTS.
Just require phone support from UE capability under generalParameterSMRDC.
(name:srb3 supported either 1 or 0).
