Hi experts,
Please help me to understand why the reestablishment handover here is rejected.
Is it because the NR bearerconfig info forwarded cause the handover failure?
//NR PDCP Configured
drb-ToAddModList
cnAssociation eps-BearerIdentity : 5,
drb-Identity 1,
reestablishPDCP true,
pdcp-Config
drb
discardTimer infinity,
pdcp-SN-SizeUL len18bits,
pdcp-SN-SizeDL len18bits,
headerCompression notUsed : NULL,
statusReportRequired true
t-Reordering ms120
securityConfig
securityAlgorithmConfig
cipheringAlgorithm nea2,
integrityProtAlgorithm nia2
//LTE HO is configured but “reestablishPDCP” IE is not configured
2022 Apr 5 04:46:44.733 [A4] 0xB0C0 LTE RRC OTA Packet -- DL_DCCH / RRCConnectionReconfiguration
Subscription ID = 1
Physical Cell ID = 301
Freq = 9310
mobilityControlInfo
targetPhysCellId 231,
carrierFreq
dl-CarrierFreq 38100
drb-ToAddModList
eps-BearerIdentity 5,
drb-Identity 1,
rlc-Config am :
securityConfigHO
handoverType intraLTE :
cipheringAlgorithm eea2,
integrityProtAlgorithm eia2
keyChangeIndicator FALSE,
Observation/Conclusion:
DUT:- Model Name:- A736BXXU1AVCA CSC:- CSC(XME), NET1(XME), NET2(XME) HW ID:- 7
QCom Build ID:- MPSS.HI.4.3.c5.1-00005-KODIAK_GEN_PACK-1.3500.53
IMEI:- 35282829003211/7 Sim ID:- 8960152203339804190F -
Device is on LTE Pcell PCI 301, Freq 9310 & in one case it was on PCI 454, Freq 9310
NR PDCP is configured, LTE HO takes place but “reestablishPDCP” IE is not configured by the NW
Since in this case LTE keys are changing as HO is triggered, so reestablishPDCP flag need to be set by the network.
Due to multiple NR Reconfig failure device goes to no service mode which is impacting user experience
Spec reference 36.331 5.3.4.5
NOTE 2a: At handover the reestablishPDCP flag will be set for all RBs configured with NR PDCP in nr-RadioBearerConfig1 or nr-RadioBearerConfig2 TS 38.331 [82] which will cause the PDCP entity to be re-established also for these RBs. -
NW to check the reason why “reestablishPDCP” IE was not included
Analysis:
drb-ToAddModList
drb-Identity 1,
pdcp-Config
drb
t-Reordering ms120
securityConfig
Subscription ID = 1
Freq = 9310
mobilityControlInfo
carrierFreq
drb-ToAddModList
drb-Identity 1,
rlc-Config am :
securityConfigHO
//In LTE HO is taking place and keys are being changes so NW should configure reestablishPDCP
04:46:44.731 nr5g_rrc_llcdb.c 43508 ELLCDB: RRC OTA validation failed. Security key changed without reestablishRLC (DRB id 1)
04:46:44.731 nr5g_rrc_llcdb.c 32512 ELLCDB: PDCP/RLC Reestablish validation failed
04:46:44.731 nr5g_rrc_utils.c 3672 HSending NR5G_RRC_CFG_STAT_UPD_IND with status (1). Overall config num_bearer (0), nr5g_sec_config_valid(0), mrdc_bc_info.lte_band_combo.num_bands(0), mrdc_bc_info.nr_band_combo.num_bands (0) num_nr_cc(0)
04:46:44.731 nr5g_rrc_llc.c 2062 ELLCDB: cfg_reqi processing for proc (4) type (0) failed ! step1_step2_status (1)
04:46:44.731 lte_rrc_config_nr5g.c 471 HReceived NR5G_RRC_CFG_STAT_UPD_IND(status:1) FAILURE due to validatn from NR5G-RRC, Triggering RLF
2022 Apr 5 04:46:44.732 [37] 0x1FFB Event -- EVENT_LTE_RRC_RADIO_LINK_FAILURE_STAT RLF Cause = RLF NR RECONGIF FAILURE
2022 Apr 5 04:46:45.475 [4B] 0xB0C0 LTE RRC OTA Packet -- UL_CCCH / RRCConnectionReestablishmentRequest
Subscription ID = 1
Physical Cell ID = 55
Freq = 6245
reestablishmentCause reconfigurationFailure,
2022 Apr 5 04:46:45.536 [54] 0xB0C0 LTE RRC OTA Packet -- DL_CCCH / RRCConnectionReestablishmentReject
Freq = 6245
2022 Apr 5 04:46:45.627 [87] 0xB0ED LTE NAS EMM Plain OTA Outgoing Message -- Tracking area update request Msg
2022 Apr 5 04:46:45.629 [83] 0xB0C0 LTE RRC OTA Packet -- UL_CCCH / RRCConnectionRequest
Freq = 6245
2022 Apr 5 04:46:45.701 [60] 0xB0C0 LTE RRC OTA Packet -- UL_DCCH / RRCConnectionSetupComplete
Freq = 6245
2022 Apr 5 04:46:49.774 [1A] 0xB0EC LTE NAS EMM Plain OTA Incoming Message -- Tracking area update reject Msg
Subscription ID = 1
pkt_version = 1 (0x1)
rel_number = 9 (0x9)
rel_version_major = 5 (0x5)
rel_version_minor = 0 (0x0)
security_header_or_skip_ind = 0 (0x0)
prot_disc = 7 (0x7) (EPS mobility management messages)
msg_type = 75 (0x4b) (Tracking area update reject)
lte_emm_msg
emm_ta_update_rej
emm_cause
cause_value = 9 (0x9) (UE identity cannot be derived by the network)
2022 Apr 5 04:46:49.774 [60] 0xB0C0 LTE RRC OTA Packet -- DL_DCCH / RRCConnectionRelease
Freq = 6245
2022 Apr 5 04:46:49.847 [BA] 0xB0C0 LTE RRC OTA Packet -- UL_CCCH / RRCConnectionRequest
Freq = 6245
04:44:04.660 nr5g_rrc_llcdb.c 43508 ELLCDB: RRC OTA validation failed. Security key changed without reestablishRLC (DRB id 3)
04:44:04.660 nr5g_rrc_llcdb.c 32512 ELLCDB: PDCP/RLC Reestablish validation failed
04:44:04.660 nr5g_rrc_utils.c 3672 HSending NR5G_RRC_CFG_STAT_UPD_IND with status (1). Overall config num_bearer (0), nr5g_sec_config_valid(0), mrdc_bc_info.lte_band_combo.num_bands(0), mrdc_bc_info.nr_band_combo.num_bands (0) num_nr_cc(0)
04:44:04.660 nr5g_rrc_llc.c 2062 ELLCDB: cfg_reqi processing for proc (4) type (0) failed ! step1_step2_status (1)
04:44:04.660 lte_rrc_config_nr5g.c 471 HReceived NR5G_RRC_CFG_STAT_UPD_IND(status:1) FAILURE due to validatn from NR5G-RRC, Triggering RLF
2022 Apr 5 04:44:04.660 [E3] 0x1FFB Event -- EVENT_LTE_RRC_RADIO_LINK_FAILURE_STAT RLF Cause = RLF NR RECONGIF FAILURE
04:46:19.571 nr5g_rrc_sec.c 1540 HRRC SEC:Received new sk_counter (0)
04:46:19.571 nr5g_rrc_sec.c 1551 HRRC SEC:Current SN cipher Algo is NEA0. Not invalidating NR keys for new sk-counter
04:46:19.571 nr5g_rrc_llcdb.c 43508 ELLCDB: RRC OTA validation failed. Security key changed without reestablishRLC (DRB id 3)
04:46:19.571 nr5g_rrc_llcdb.c 32512 ELLCDB: PDCP/RLC Reestablish validation failed
04:46:19.571 nr5g_rrc_utils.c 3672 HSending NR5G_RRC_CFG_STAT_UPD_IND with status (1). Overall config num_bearer (0), nr5g_sec_config_valid(0), mrdc_bc_info.lte_band_combo.num_bands(0), mrdc_bc_info.nr_band_combo.num_bands (0) num_nr_cc(0)
04:46:19.571 nr5g_rrc_llc.c 2062 ELLCDB: cfg_reqi processing for proc (4) type (0) failed ! step1_step2_status (1)
04:46:19.571 lte_rrc_config_nr5g.c 471 HReceived NR5G_RRC_CFG_STAT_UPD_IND(status:1) FAILURE due to validatn from NR5G-RRC, Triggering RLF
2022 Apr 5 04:46:19.572 [81] 0x1FFB Event -- EVENT_LTE_RRC_RADIO_LINK_FAILURE_STAT RLF Cause = RLF NR RECONGIF FAILURE
