While modifying InterRatReportMode from PERIODICALLY_REPORTING to EVENT_TRIGGER in RNC oriented coverage based IRAT HO Measurement Algorithm.
what are the other parameters to be considered?
Objective: Reduction of signaling load.
Parameter to set measurement reports to be periodic or event-based in Huawei LTE? | 4 | 985 | August 19, 2017 | |
Which is the best option of measurement reporting: periodic or event triggered? | 1 | 404 | August 13, 2021 | |
Amount of measurement report | 0 | 637 | August 15, 2022 | |
Ericsson parameter to change the "resource allocation strategy" | 1 | 822 | August 22, 2020 | |
IRAT Handover issue | 0 | 1116 | August 19, 2017 | |
Impacts of inter RNC inter frequency attempts in HO procedure | 5 | 538 | May 12, 2021 | |
UE switching to much from 3G to 2G | 1 | 381 | June 6, 2021 | |
What all are RRC Failure Optimization Key Points & Parameters? | 0 | 481 | March 23, 2023 | |
Transmission KPI in LTE | 2 | 663 | October 27, 2021 | |
Parameter to Forbid PS UTRAN HO | 3 | 358 | March 5, 2021 |
