Is FDD-TDD CA technically possible currently?
Hello all.
Has anyone implemented it in their network?
Sure!
I have seen it since 2016.
Lots of current networks use it.
For example Band 38 + Band 3 + band 8
Yes, but need UE support as well.
IE there in UE capability information indicating fdd-tdd ca support.
Yes it is possible and is widely used these days.
We are using it with FDD Band 1/3/7 with TDD Band 40 successfully.
The Carrier Aggregation FDD-TDD function enables the diversion of downlink traffic onto the TDD spectrum, overcoming the restrictions imposed by the TDD carrier’s limited uplink application coverage.
This setup allows a User Equipment (UE) to utilize the extensive coverage of FDD Uplink while benefiting from the significant performance enhancement offered by the TDD carrier for Downlink operations.
Yes we did it with Nokia equipment FDD band 1 3 20 and TDD 41.
