The BAlist in 2G Huawei gets updated automatically when you declare a new neighbor in the neighbor table of a cell.
My question is: is there a posibility to manually add frequencies into the BAlist without needing to add a neighbor?
Yes, it can be added manually.
Sounds good gentlemen, thanks for the feedback!
Where can find the associated commands for the BAlist?
You can try below command:
LST / MOD GCELL2GBA1
(It’s long time, not able to recall exact command).
I’ll start looking from this point, thank you very much!
