Hello All.
Is it possible to open a KML file in a excel sheet?
Hello All.
Yes it is possible, but you need to do a couple of steps before. 1st need to change the file extension to .xml (Just hit F2 when selecting the file then filename.kml → filename.xml) then use import option from excel as xml. As an advice always do a copy of the original file before changing the file extension.
Another way to do it is using a GIS tool like Q-GIS or Global Mapper.
They use to have a conversion tool directly from KML/KMZ to Excel.
The conversion works fine, both way.
Yes, try QGIS (it is free open source).
