Is there any impact on TM9 without CSI-RS config IE in RRC connection reconfiguration message?
Hi All,
I have query: without CSI-RS config IE in RRC connection reconfiguration message any impact on tm9?
Will it work or not?
there are 2 configurations related to TM9 (PMI feedback independent and feedback dependant on PMI)
1- TM7, TM8, or PMI feedback-independent TM9 (like an open loop), the eNodeB determines the downlink channel characteristics based on sounding reference signals (SRSs).
2- In PMI feedback-dependent TM9 (like a closed loop), the UE estimates channel quality based on channel state information-reference signals (CSI-RS), and then provides channel state information (CSI) feedback to the eNodeB.
in your query, you are referring to case 1 where SRS is sent by UE and the EnodeB assigns the beamforming to UE by weighting channel quality.
however, in both cases, TM9 can still be used.
you can refer to the following picture for better understanding:
