The VoiceBearerInHandoverCommand parameter specifies if the voice bearer is sent in the Handover Command message for the SRVCC, with or without PS handover procedures.
Is there anything which we can control bearer in huawei MME ?
What is the parameter name in Huawei mme of this voicebearerinhandovercommand? | 2 | 1013 | March 20, 2018 | |
Counters in 5G for GBR bearers (VoNR for example) released when QoS cannot be fulfilled | 4 | 790 | March 13, 2021 | |
Timer controlling RA response window | 3 | 286 | June 23, 2023 | |
What happens to the ENDC bearer during VoLTE call? | 3 | 827 | October 12, 2022 | |
SRVCC Configuration: Can It be set up like Blind Handover or only with Measurements? | 6 | 25 | September 12, 2024 | |
Can SB Handover in Huawei be controlled at cell level? | 6 | 1511 | August 12, 2017 | |
Parameter to reduce MCS fluctuation | 0 | 455 | June 16, 2021 | |
Handover based on SINR in LTE | 3 | 538 | December 23, 2022 | |
No value for L.FlashCSFB.E2W | 1 | 1284 | May 8, 2019 | |
MML command to check Filter Coefficient | 3 | 510 | October 15, 2020 |
