Hi All.
Is there Inter-RAT Interference in DSS Cell Overlapping area?
Anyone see this issue?
Hi All.
Yes, if you have 5G DSS in 2100 interfere 4G L2100.
Like if you have -85 dBm in 4G L2100, the SNR is very low 1-2 dB , because of 5G DSS neighbours cells.
LTE interference on NR | 1 | 330 | February 9, 2024 | |
Can overlapping ARFCN in most of the NR bands cause interference? | 0 | 430 | December 23, 2022 | |
Nr-dss | 0 | 534 | February 25, 2022 | |
5G overshooting causing issues for sgnb addition | 3 | 597 | June 29, 2021 | |
Minimum RSRP between Serving and Neighbor cell to avoid SINR degradation | 3 | 533 | September 8, 2021 | |
LTE and NR synchronization requirement during inter-RAT measurements | 1 | 909 | July 29, 2022 | |
Estimate UL SINR using DL measurements in LTE and NSA NR | 1 | 952 | May 10, 2021 | |
Can the LTE Band used for DSS be aggregated? | 1 | 613 | June 1, 2022 | |
5G FDD DSS (Dynamic Spectrum Sharing ) and Time Synchronization | 0 | 166 | May 20, 2024 | |
5G throughput is degraded with high iBLER / Retransmission in DL | 4 | 1151 | February 10, 2022 |
