Does anybody tested VoNR via Apple iPhone?
I’ve heard they will not support it for some regions, is it true?
VoNR available after 14 Pro only.
Thanks!
Do you know the reason?
Apple said that for unknown carrier it’s not going to be enabled.
No forecast when either.
A lot of SA network in current rollout.
I think someone need to convince Apple for VoNR…
In my country, Apple also allow VoLTE only for operators who deploy big enough.
VoLTE became like a mandatory and it’s working as fallback from 5G SA, so it is normal.
VoNR is a bit different, IMS has to be integrated with 5G core and 4G is not needed anymore, as you may know.
Yes, iOS18 is like that already.
Unless VonR is stable at operator side, Apple won’t activate in the iOS.
For me in Spain VonR is not available for iPhones.
But Indian operator JIO supports VoNR, in Mumbai.
Thank you!
++ Kolkata.
Correct, Iphone 14 Pro and above must be supporting VoNR, ViNR.
