In DWDM :
We use single mode fiber for long distance traffic transport.
We use C band and L band because the lowest attenuation level.
We use ROADMs for channels adding, dropping & pass through via WSS.
We use coherent detection systems in case of long distance, High capacity and no need for DCM.
We could achieve ultra high capacity on single channel like 100, 200, 400 Gbps or even higher in special cases.
We use Qpsk & 16 Qam modulation for coherent detection systems.
We use optical amplifiers for distance extending like EDFA & RAMAN , meanwhile EDFA add noise ASE.
We use optical line protection and SNCP , MSP & MSP ring.
We use OTN frame for data Transportation in L1 and mangment , the frame contains 3 layers (OPU , ODU , OTU).
We use CDC Roadms in case of higher traffic routing flexibility needed (colourless , directionless , contentionless).
We use flexgrid and fixed grid channels, for fixegrid the frequency spacing is fixed and predetermined like 50 & 100 Ghz.
In flexgrid we could use variable spacing allows dynamic adjustment of channel spacing, making it much more efficient and scalable, especially in high-capacity optical networks.
LinkedIn:
