Hi everyone,
can you tell me how I can understand if an access attempt to the RACH has been rejected with TA exceeded?
Both in case of contention and without contention.
Thank you
Hi everyone,
Thank you
There is counter CBRA discard OOC (out od Coverage).
You should check it in customer product informatiom doc.
Time Advance and Service Limit | 0 | 379 | March 24, 2023 | |
What can be done to avoid RACH fail in 5G SA as RACH is contention based? | 2 | 515 | October 4, 2024 | |
KPI (Core/BSS/RAN) or other way-forward for getting Out Of Coverage time of any UE | 1 | 455 | September 26, 2020 | |
DRB addition failure | 1 | 776 | October 31, 2021 | |
What could be the reason for high TA (Timing Advance) in a LTE cell just near the tower? | 5 | 393 | September 27, 2024 | |
RACH SR for contention based is very bad while contention free SR is good | 3 | 251 | March 16, 2024 | |
Reduce RRC rejections in a site | 0 | 562 | April 10, 2020 | |
Transmission KPI in LTE | 2 | 671 | October 27, 2021 | |
LTE cells with very high PUSCH RSSI on multiple bands across the network and RSSI does not follow traffic | 0 | 239 | December 30, 2023 | |
Possible causes for LTE RRC Success Rate degradation in Connection Establishment | 8 | 71 | November 14, 2024 |
