hello Engineers
I’m here asking about the main/important KPIs for 3G optimization, and methods of analysis.
thanks
Main 3G optimization KPIs and methods of analysis
Here are some of the main KPIs for 3G optimization, along with methods of analysis:
Cell availability:
This is the percentage of time that a cell is available to users. It can be measured by the number of dropped calls or the number of times a user is unable to access the network.
Call setup success rate:
This is the percentage of calls that are successfully established. It can be measured by the number of calls that are dropped during the setup process.
Call drop rate:
This is the percentage of calls that are dropped during the call. It can be measured by the number of calls that are dropped after the setup process is complete.
Packet session setup success rate:
This is the percentage of packet sessions that are successfully established. It can be measured by the number of packet sessions that are dropped during the setup process.
Packet loss rate:
This is the percentage of packets that are lost during transmission. It can be measured by the number of packets that are received with errors.
Mobility performance:
This is a measure of how well the network handles user mobility. It can be measured by the number of handovers that are successful or the number of times a user is dropped during a handover.
Integrity performance:
This is a measure of how well the network protects data from corruption. It can be measured by the number of errors that are detected in data transmissions.
These are just some of the most important KPIs for 3G optimization. The specific KPIs that are most important will vary depending on the specific network and the goals of the optimization process.
The methods of analysis that can be used to measure these KPIs include:
Data collection:
This involves collecting data on the performance of the network. This data can be collected from a variety of sources, such as network probes, call detail records, and user surveys.
Data analysis:
This involves analyzing the data that has been collected to identify areas where the network can be improved. This analysis can be performed using a variety of statistical tools.
Recommendations:
This involves making recommendations for how to improve the network based on the results of the analysis. These recommendations can include changes to the network configuration, the addition of new hardware, or the implementation of new software.
The process of 3G optimization is an ongoing process that requires regular monitoring and analysis of the network performance. By tracking the KPIs that are most important for the network, and by making recommendations for improvement, network operators can ensure that their networks are performing at their best.
Credits:
Thanks Engineer
kindly, can i get any data for KPIs analysis and procedures.
