L1 crash
Hii the issue is that L1 is crashing due to memory full
                          |  MAC |     MAC-to-PHY Tput    |                PHY-to-MAC Tput                 |  UL FEC CB Iterations |
   Cell (MU / DL,UL MHz)  | Inst |      kbps       Num CB |             kbps           UL BLER      Num CB |    Min    Avg    Max  |      SRS SNR
       0 (MU 1 /  70, 70) |   0  |    988,857     589,963 |        312 /        362     13.82%       2,001 |      1   2.07     12  |      0 Db
Core Utilization [4 BBU core(s)]:
    Core Id :      4     5     6     7     Avg
  Numa Node :      0     0     0     0
     Util % :   9.83  9.59  9.45  9.59    9.62
     Intr % :   0.33  0.34  0.34  0.34    0.34
    Spare % :   0.35  0.35  0.35  0.35    0.35
    Sleep % :  89.47 89.70 89.84 89.70   89.68
     Numa % :   0.00  0.00  0.00  0.00    0.00
    TTI Cnt :  10002 10002 10002 10002
    TTI Min :      0     0     0     0
    TTI Avg :      9     9     8     9
    TTI Max :     67    67    67    67
    Active Cores : Min[     0] Avg[  0.00] Max[     0]
     Xran Id:   8   9     Master Core Util:  54 %
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 458 18)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 0)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 1)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 458 19)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 2)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 0)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 3)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 1)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 4)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 2)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 5)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 3)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 6)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 4)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 7)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 5)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 8)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 6)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 9)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 7)
[err] file[auxlib/wls/aux_wls_mac2phy_api_recv.c] func[wls_mac2phy_api_recv_add_late_api] line[318]: Cleanup Queue is Full
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 10)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 8)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 11)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 9)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 12)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 10)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 13)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 11)
[err] file[nr5g/api/mac2phy/gnb_mac2phy_api_proc.c] func[nr5g_gnb_mac2phy_api_proc_get_new_list] line[588]: Stopping Phy because MAX_SUCCESSIVE_NO_API_TTIS_BEFORE_STOP: 15
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(DL): phyInstance[0] inc[1]  (sfn: 459 14)
nr5g_gnb_mac2phy_api_error_check_use_empty_channels(UL): 0 1  (sfn: 459 12)
Stopping because: PHYDI_STATE_FORCE_STOP. gStop = 0
Timeout from stopping XRAN_timing_thread.. [10000]
Disable RU0 CC0 [0000000000000000:0]
Timing Thread is not running! 0
phydi_stop[from 8]: phyInstance: -1, sendStop: 0, phyIdStart: 0, phyIdStop: 40
MLogPrint: ext_filename((null).bin)
    Opening MLog File: l1mlog_wls-c0.bin
    MLog file l1mlog_wls-c0.bin closed
    Mlog Print with Time successful
    PHY_STOP PhyInstance[0] nPhyDiState[4] nPhyDiStartMode[4] nPhyDiStateCount[0]
XRAN Stop! RU0 [1]
  Received total number of stops! Stopping......
fh_rx_bbdev-9 worker thread finished on core 9 [worker id 0]
EBBUPOOL [INFO][ebbu_pool_consumer_remove_all_cores]:Destroy the consumer thread 0 in core 4 successfully!
EBBUPOOL [INFO][ebbu_pool_consumer_remove_all_cores]:Destroy the consumer thread 1 in core 5 successfully!
EBBUPOOL [INFO][ebbu_pool_consumer_remove_all_cores]:Destroy the consumer thread 2 in core 6 successfully!
EBBUPOOL [INFO][ebbu_pool_consumer_remove_all_cores]:Destroy the consumer thread 3 in core 7 successfully!
EBBUPOOL [INFO][ebbu_pool_consumer_remove_all_cores]:All consumer threads are destroyed!
EBBUPOOL [INFO][ebbu_pool_maintenance]:Framework Maintenance thread is destroyed successfully!
EBBUPOOL [INFO][ebbu_pool_release_threads]:Threads Released successfully!
EBBUPOOL [INFO][ebbu_pool_release_queues]:Release queues successfully!
EBBUPOOL [INFO][ebbu_pool_release_handler]:Release handler successfully!
phydi_shutdown[from 8]: phyInstance: -1, sendStop: 0, testFileName: 0, phyIdStart: 0, phyIdStop: 40
PHY_SHUTDOWN PhyInstance[0] nPhyDiState[32] nPhyDiStateCount[0]
XRAN Close RU0 [0:00000000]
mem_mgr_display_size:
Num Memory Alloc: 20
Total Memory Size: 183,731,456
wls_print_stats
nWlsInst[0] nCellMapping[0x0000010000ffffff]
Cell QueueAlloc  CellAlloc   CellSend      Diff1       Diff
   0   18202938   18202842   18202842         96          0
   1         96          0          0         96          0
   2         96          0          0         96          0
   3         96          0          0         96          0
   4         96          0          0         96          0
   5         96          0          0         96          0
   6         96          0          0         96          0
   7         96          0          0         96          0
   8         96          0          0         96          0
   9         96          0          0         96          0
  10         96          0          0         96          0
  11         96          0          0         96          0
  12         96          0          0         96          0
  13         96          0          0         96          0
  14         96          0          0         96          0
  15         96          0          0         96          0
  16         96          0          0         96          0
  17         96          0          0         96          0
  18         96          0          0         96          0
  19         96          0          0         96          0
  20         96          0          0         96          0
  21         96          0          0         96          0
  22         96          0          0         96          0
  23         96          0          0         96          0
  40   22085730   22085635   22085635         95          0
xran_timing_source_thread:2265[err] poll_next_tick too long, delta:2982720262(ns), tUsed:4463677606(tick)
Closing timing source thread...
PHY>
PHY>
PHY>
PHY>
PHY>
PHY>stopphy
begin stopping phy (0)...Timing Thread is not running! -1
PHY>application termination...phy_print_thread:                      [PID: 2362807]... Stopping
BBDEV Stats: Enqueued (1256308418) | Dequeued (1256308418) | Enqueue Errors (0) | Dequeue Errors (0)
BBDEV Queue's Stopped for device 0
wls_nrt_mac2phy_api_recv_thread:  [PID: 2362806]... Stopping
wls_layer_close:WLS interface termination...
wls_stop_rx_thread:Termination WLS Receiver thread...
wls_layer_close:WLS Free ....
wls_layer_close:WLS Close ....
        wls_lib: WLS_Close
        wls_lib: un-link: 0 <-> 1
WLS_Close(0): nWlsClients[1]
wls_layer_close:Done
    generate tracelog file [./phy_tracelog_wls.log] in L1APP directory successfully
Cleanup after [PID] 2362622
what can be possible reasons and how to resolve ?
