Which Layer3 message can I check the NR Throughput during UE session?
If possible, could you share any example?
Hi @Cesar_Nunes there is no way, any throughput check in RRC layer, the throughput only could be measured at PDCP, RLC, MAC and Physical layer…RRC (Layer3) only used for carrying signaling.
Not sure if it helps, but a few suggestions for it, depending on what you are trying to look at:
- MDT
- NW traces, especially for Hauwei, have a lot of information, including throughput.
- Probes
I have some questions regarding t5G Throughput.
- Where can I get the UE DL actual throughput value? on PDSCH thp or PDCP thp?
- Normally cell thp is higher than UE thp but what ratio should I expect, is it normal DL Cell thp:150 Mbps vs DL UE Thrp: 18 Mbps
Thanks in advance.
