Load Balancing Behavior in Ericsson LTE Network
Hello friends.
I noticed in an Ericsson LTE network that the load balancing parameter is set to 0 from 700 MHz cells to AWS/1900, but it is set to 1 from 1900/AWS to 700 MHz.
Why is load balancing allowed from high band to low band but not the other way around?
Hello, there is a load balancing feature available between bands.
What is the deployed bandwidth and PRB utilization for each channel?
In the past, we disabled load balancing from high to low band and saw significant improvements.
I’m not sure about your network situation, but if the low band has load issues, it ideally shouldn’t be enabled.
Maybe a few priority cells have these settings to avoid congestion, but ideally, it should be enabled both ways.
