Dear Experts,
Do you have any idea for load balance on LTE different frequencies?
I also have same query:
LTE L1800 and L900 cell level traffic balance.
Huawei system.
Any suggestions?
I assumed those two cells are co-sector,
- Layering should be L1800 higher prio than L900
- MLB on active user threshold or utilization should be adjusted with regard of highest-utilized band
- RS, Pa & Pb can be adjusted, RS reduction on highest utilized cell (with Pa & Pb modification as well, so you’ll have same amount of total power)
- RET modification
- physical antenna adjustment
Just my two cents
