Hello All.
I have 1/3 cells with Payload <1 GB and DL PRB utilization 20 %, but Throughput < 1.5 Mbps in capacity layer.
Coverage layer carrying good Throughputpt and Payload & PRB.
What can be the issue?
Hello All.
Are you sure there no hardware faulty over the site ?
Did you make Drive test around the site to check it’s performance?
These are the typical symptoms of:
Cell has hardware issue such as VSWR
There is strong interference and hence spectral efficiency is low (SE lower than 1 bit/sec/hz usually means there is DL interference). You can check pusch/pucch SINR and RSSI for UL interference.
3.There is license shortage. For example DL baseband capacity license is not enough and it is not possible to use maximum capacity of the baseband board.
Parameter discrepancy is also a possibility. For example your capacity layer has discrepeancy in MIMO setting and maximum Rank is limitted.
what will be reason for PRB is 70% , payload <1GB, DL cell thpt < 1.5 mbps ?
those cells what will be reason?
Below some points about low throughput issue to be checked:
Poor coverage (BLER)
Availability issue.
Uplink Interference.
A poor RACH decoding SR.
High error on S1 link.
Delay on S1 link towards MME & SGW.
Accessibility issue.
Handover failure.
Lack of PRBs.
Problematic UE.
Downlink Interference (Bad CQI)
MIMO Parameters
High VSWR
High radio errors or instability issue.
Maximum number of RRC connections active per cell
Maximum number of users per TTI supported per cell.
Core network, MME/SGW, etc
Transmission instability & bottleneck.
Incorrect parameter setting.
Badly tuned handover parameters.
High traffic on Cell limit THp
Radio Analysis . Downlink :
Radio Analysis – Uplink :
Credits:
thank you.
