Hi All Experts.
How to get lte ECELL ID from this 28 Bit Number?
00110000 11110000 00100000 0111
Hi, there is a calculator for this in this website:
But only till 4G, support.
For 5G you can use:
But can’t be just convert above bits into decimal?
No, I am not getting it by simply converting it into Decimal…
Ok, so above bits are what?
Like cell identity or gNB ID.
I mean what does this 28 bits signify here?
ENB ID ( Normally 20 bits ) + Cell ID ( 8 bits)
Formula should be eNodeB ID * 256 + Cell ID for 4G: What is the formula for Cell ID (ECI) in LTE networks? - #23 by Fathy_Farouk
Remove 8 LSB and covert rest binary to decimal.
