Hi guys.
I have issue with power calculation related to
type of RRUs.
For example
2T2R
4T4R
How I can calculate them in a right way.
Also what’s the difference between CPICH power and
the power which I can see
In
LST UCELL
Command
Hi guys.
type of RRUs.
For example
2T2R
4T4R
In
LST UCELL
Command
GSM power check | 1 | 497 | May 26, 2024 | |
Is there any indicator shows the real power of BCCH in 2G? | 5 | 1132 | March 12, 2021 | |
5G Reference Signal Power Calculation | 2 | 4048 | March 2, 2022 | |
4T4R more PHICH and less PDCCH in slot zero of subframe as compared to 2T2R | 0 | 438 | July 1, 2020 | |
KPI formula of DL spectrum efficiency in Huawei | 3 | 2457 | July 19, 2020 | |
How to calculate "CRS spectral power density " of a 40W LTE Cell? | 0 | 457 | May 26, 2023 | |
Formula with higher throughput values | 1 | 871 | February 9, 2022 | |
How to calculate PUSCH Throughput? | 0 | 174 | April 22, 2024 | |
How to calculate UEs per TTI? | 0 | 198 | May 15, 2024 | |
How to calculate CQI step up and CQI step down? | 0 | 253 | March 25, 2024 |
