LTE PUCCH Resource Allocation depends on the connected user or not
Kindly I need to know if the resource allocation for PUCCH (LTE) depends on the connected user or not.
Thanks
Increasing admission control for the number of RRC connections requires an increased resource allocation for the PUCCH .
Admission Control will check the availability of PUCCH resources when admitting a new RRC connection. The connection will be rejected if the PUCCH resources are already fully utilised. The allocation of PUCCH resources should be aligned with the maximum number of RRC connections permitted within a cell .
max Num of Active UE should be to equal the value allocated to the max Num of RRC
thank you very much, really good detail
