Hello ,
LTE site observed with browsing issue when tested for apps such as gmail, youtube, Ookla (speedtest) etc… however the site works fine when tested for FTP DL/UL.
what can be the possible reason for this behaviour?
Hello ,
ping from ENB to ‘Next Hop IP’ and if there is packet discard .
then Involve IP & transmission team to check the MTU setting on their equipment.
adding to @cheikh789, it worth to mention the OLTs vendor and performance on both nodes
DO you mean that, you during HTTP throughput testing site is having issue or you cannot browse any site at all?? Please check the Gateway for this case…
dear Gents ,
i have this problem in LTE Drive test for one LTE site that have a consignation in MW link or the DWDM
when i test FTP i got 200 M and oklaa 70 M
can any one explain to me the difference between ftp drive test and OKlaa test , using protocols
process used in both
is FTP using TCP tests only
is oklaa using TCP and HTTP
wait your reply
thanks
