mmWave typical User Throughput
Can anyone share typical user throughput in mmWave for
100
200
300
400
500
600
700
800
Mhz spectrum scenarios
Have experience of following:
  • 100 Mhz - Single carrier - 470 Mbps
  • 400 MHz - 4CC - 1.7 Gbps
  • 800 MHz - 8CC - 3.6 Gbps
These are Ookla Speedtest values.
If you have good FTP server available then may achieve upto 4 Gbps.
Are these average user speed or top speed?
I am looking for average user DL throuput and UL throughput.
These are peaks.
Not done much of average based test.
Which setup are these from?
The DL and UL throughputs will depend on the DL/UL Ratio that is being used
Next, for average throughputs, you will need to know the SINR (or C/(N+I)) at different locations since the rate will depend on MCS.
You may need to use a packet simulator like NetSim (https://tetcos.com/5g.html) to check across all these different scenario (bandwidth, distances, DL/UL ratios, LOS/NLOS etc)
