Modulation MCS used in LTE signaling: is it fixed to QPSK?
Hello Huawei Experts.
Can you confirm if the modulation MCS used in LTE signaling is fixed to QPSK?
Do you mean during the attach stage or later?
For initial messaging, it’s fixed.
After that, I believe it uses the same MCS as PDSCH-A.
In NR, PDCCH uses QPSK only.
Thanks! Yes, I mean for the initial stage.
Is it configurable?
Which parameter controls this, and in which message can we find it?
Check with the vendor.
From what I understand, it’s hard-coded and not configurable.
Are you looking to set it to a higher MCS or lower?
I would like to check because the MCS is 100% QPSK.
I want to verify if this is due to initial access.
Ah, okay. If the entire traffic in the cell is 100% QPSK, it could be a licensing issue. Most phones now support higher MCS, so it’s likely that the license is limiting the higher data rates.
As soon as the phone switches to closed-loop power control, the MCS adjusts dynamically.
But is it true that the MCS is fixed at QPSK for initial access?
I believe so, yes.
Do you know which parameter controls this?
It’s hard-coded and not changeable. This is based on my own experience when I looked into this behavior. I even asked Huawei about it at the time.
  1. Check TB size, small data → no need for higher modulation order.
  2. UE RF condition can be bad → need to maximize successful transmission rate
