Do you have some comments on how to run Monte Carlo simulation in Atoll?
- Network tab → Simulation → right clcik → new
- General tab: set number of simulation
- Traffic tab: select the traffic map to be used + set the global scaling factor
- 4G/5G tab leave it as default
- Advanced: generator initialization can be 0 (for user position randomness per simulation) or anything else than 0 to keep same user position (help for comparison) // set max number of iteration
- Calculate
