Can you tell why there is 30% more gain for SRS based weight as compared to PMI based weight?
SRS carrier switching improves SCell capacity.
Massive MIMO performance improves by 30% when SRS-based weights are used (vs. PMI-based weights)
This is because SRS based weights are pointing the beam more precisely on user, with max gain/SINR on it, whereas PMI based weights are not so precise to point the beam with max on user.
Try reading this article to understand how different is srs and pmi weights: Types of beamforming in 5G:
