Most used Microwave link diffraction method
What diffraction method do you use in these options?
Here are the settings I use in Atoll for different propagation models:
Aster
  • Vertical diffraction over rooftops based on Walfisch-Ikegami model and multiple knife-edge Deygout method.
  • Horizontal diffraction based on ray tracing.
CrossWave
  • CrossWave applies the Deygout method for determining wave diffraction losses.
SPM (Standard Propagation Model)
  • Deygout (default)
  • Epstein-Peterson
  • Deygout with correction
  • Millington
Okumura-Hata
  • Knife-edge Deygout method
It seems to me that Deygout is the most used.
Which is this tool?
It is CloudRF
Simple, powerful, great support, on the Cloud and cheap.
