Hello Experts, Need your comments on this , CA between two bands ,supposed L1800+L2600 whereby PCell is L1800 and SCell is L2600 so if UE is camped on L1800 then CA works fine but if UE is on L2600 then does this CA still works? Can anyone confirm this ?
both same mhz??? for example if 1800 is on 5Mhz and 2600 having 20Mhz then it will not work
i know this further lets reply experts
L18 is 10Mhz and L26 is 20Mhz. Does it really depend on how much bandwidth each layer has ?
yes if parameter define like that
Well I thought it’s all about how Pcell and Scell is configured ,irrespective of their bandwidths
ca is fail if you have super cell or umbrella cell
Can you please elaborate super cell here ?
its like physical connectivity over both band.
both layer power will higher of lower band and lower power of higher band
coverage of lower band capacity of higher band
layer balancing should be off
physical connection via SRIO cable
For Nokia you need SRIO but for huawei you don’t
Experts,can anyone confirm CA can work in this kind of situation ?
ok than do it
Yes it will work. With configuration u can…Other is traffic volume too
Which configuration you require? You mean CA config should be capable of doing this
You can do with more than two bands as well
Yes CA configuration
3ca it is also possible. CA aware feature will work here…if huawei have
3ca as well
2CC with 3CA
3CC with 3CA
2CC with 2CA
Will confirm it’s working in my network
MOD ENODEBALGOSWITCH:CAALGOSWITCH=PdcchOverlapSrchSpcSwitch-1&CaCapbFiltSwitch-0&PccAnchorSwitch-1&SccBlindCfgSwitch-1&FreqCfgSwitch-0&SccA2RmvSwitch-1&CaTrafficTriggerSwitch-1&HoWithSccCfgSwitch-0&SccModA6Switch-0&GbrAmbrJudgeSwitch-1;
RF script includes the below content:
ADD CAGROUP;
ADD CAGROUPCELL;
ADD CAGROUPSCELLCFG;
Add neighbor cell relation.
Hope it will help
Which one of this switch is specifically for that ? Because UE is camped on L2600 which configured as a Scell so does Pcell gets activated automatically ?
All switches, if u want configure pcell and scell configure in other first commands
