Hi All,
NBR is deleting automatically from 4G sites.
Can anybody tell me the reason?
Check if ANR is enabled for deletion.
Do you have ANR enabled?
You can check SON log if ANR automatic delete NBR or not.
If ANR is set with acute limits.
Need to check ANR deletion settings.
Also check removeNcellTime.
